Mariusz:
Check for corrupt .mnr (menu resource files), as they can cause this. In
most cases, these should be recreated automatically if you just delete them.
There are of course many other possible causes. 🙂
Owen Wengerd
President, ManuSoft <>
VP Americas, CADLock, Inc. <>
"MariuszK" wrote in message news:5802647@discussion.autodesk.com...
When starting AutoCAD LT 2005 user receives the following error message:
"Error handler re-entered. Exiting now."
After clicking OK AutoCAD closes.
The problem has appeared suddenly - there were no installations or setting
changes in the meantime. User was trying to do something for his own:
- "clear" reinstall (deleting the folders and registrty keys) and Service
Pack 1
- scandisk - no errors found
- antivirus, spyware - no viruses, trojans, spyware etc.
- restoring the system to a "working" day
- creating the new administrator account and starting the program
- starting in the diagnostic mode (the same error, no more information)
Nothing helps, nothing found in the Knowledge Base. BUT... The day that the
error occured was 12.12. The same day seven updates were installed
automatically by Win XP, so the customer assumed that the AutoCAD error was
caused by the updates. He did another"clean" AutoCAD uninstallation, then
removed all seven updates (restarting the system after each removal),
installed AutoCAD LT 2005 + SP1 but the error still appears and the software
can't be used.
Please share ANY suggestions and comments - is it hardware issue, or can the
system reinstallation help, or whatever, could Windows updates somehow
affected the files used by AutoCAD and results in "handler" error...
It's serious problem so I will be extremly grateful for any ideas.>>
