Unable to Install AutoCAD LT 2017
HELP! why would 0 of 1 seat be unavailable? download of LT 2017 FAILED. auto-renew sunscription processed 09 May 2016 any thoughts/ suggestions?
jeffrey.sin
Hi @Anonymous,
Welcome to the Community.
The 0 of 1 seat available indicates that the available seat on subscription is already assigned to a named user. I checked the details and the single seat of AutoCAD LT is currently assigned to you so that shouldn't be an issue and you should be able to access your AutoCAD LT subscription using your own account.
With regard to the download failing, could you provide the error message that you were getting so we could troubleshoot further? Also, you may opt to try the other download methods available from your account. You can find these by changing the platform and language options in the download menu.
Let us know how it goes. Thanks.
Jeffrey Sin
Autodesk Customer Support
pendean
Community Legend
Community Legend
You can also get your 2017 downloads through a direct link here http://forums.autodesk.com/t5/installation-licensing/community-downloads/td-p/6314550
stevetamplen
Hello avila.n4, and welcome to the Forums!
Did Pendean or Jeffrey's post get your two problems resolved?
If so, please hit the Accept as Solution button for the post(s) that helped so that more community members can profit from the solution.
If not, please post back and someone will help you until the issue is resolved!
Steve Tamplen
Technical Support Specialist
stevetamplen
@Anonymous;
Did any of the posts get your problem(s) resolved?
If so, please hit the Accept as Solution button so that more community members can profit from the solution.
If you still need help, please post back with more details!
Steve Tamplen
error message when i tried downloading from link provided by AutoDesk.
AutoCAD LT 2017 32 Bit
http://efulfillment.autodesk.com/NET17SWDLD/2017/ACDLT/DLM/AutoCAD_LT_2017_NWL_English_Win_32bit_dlm...
need 64-bit link
Thanks to all! Looks like I needed to uninstall and then reinstall security software. AutoCAD LT 2017 up and running!
