UCS Rotating Automatically
Hi everyone,
Your help would be much appreciated.
I have just downloaded and subscribed to AutoCAD LT and I am having problems with the UCS rotating automatically.
When I first draw on model space, everything is fine. When I go to the layout view and press the model tab to fit my sketch into the window, it rotates the UCS automatically, without rotating the actual drawn objects.
How do I stop the UCS from rotating automatically?
Thank you in advance.
steven-g
Can you show us a screenshot of what you are seeing?
pendean
Community Legend
Community Legend
Is your UCS rotated on purpose? UCS command should be set to WORLD if not.
Is PLAN command set to Current UCS on purpose? If not, set it to WORLD as well.
Look up both in HELP.
Do you have UCSFOLLOW variable turned on? See usage in HELP and turn it off.
HTH
