Trim and Extend Commands
sbaker9VZXU
Message 1 of 17
sbaker9VZXU
With the latest update they have changed the trim and extend commands.  I typically like to select trim and then hit "enter" "enter" which allows me to trim as much as I want over and over again.  It used to allow me to draw those trim commands as rectangles and now it is a squiggly line that is much harder to control.  Is there a setting that would allow me to go back to the way it was?
Thank you,
Replies (16)
Message 2 of 17
pendean
Community Legend
Community Legend
LT2021? squiggly lines? Post a screenshot please.
If you want to go back, why use LT2021 in the first place? I'm curious more than anything really.
Message 3 of 17
steven-g
Which version have you updated from? The squiggly line selection has been around for quite some time, instead of holding your left mouse button down when you try to do a window selection you should start the window with a mouse click then release the button and only click again when you want to pick the opposite corner.
Message 4 of 17
sbaker9VZXU
Thanks for the reply.
I was using 2020 LT and upgraded to 2021 LT.  I tried your suggestion below but it does not seem to work.
Seems like a pretty big change to the way to trim things, really hoping they have an option to use it like I was.
Message 5 of 17
sbaker9VZXU
I cannot screen shot as if I let go of the mouse the command exits.  It's basically making me use something similar to the lasso command to trim and extend.  I will be going back to 2020 if I do not resolve this.  No biggie either way I guess.
Message 6 of 17
cadffm
It is a good idea to learn FIRST about changed and new things, then use the new Version.
The updated commands trim&extend are the best sample.
You can watch videos about the new thing, it explains how it works now
and how you can change it.
Wait some hours/days, so you can take a look in to the [F1]Help.
My German version is available, the english version not. Check it out tomorrow again.
http://help.autodesk.com/view/ACD/2021/ENU/
For you:
Variable: TRIMEXTENDMODE
1 is default and the new style
0 is the old style.
My advice: Learn first the new thing, then disable it if you like.
Sebastian
Message 7 of 17
cadffm
Note, the variable is stored in your draft file! (sounds stupif for me, but we can not change it)
0 - Standard operation
1 - Quick action
GoogleTrans
This system variable controls the default mode when using the commands TRIM and EXTEND. In the standard mode, you first enter all cut or stretch boundaries. The quick mode has the following effects:
All objects in the drawing automatically serve as TRIM or stretch boundaries.
By default, objects to be trimmed or stretched can be selected with a two-point fence, a push-pull lasso, or individually.
Note: The optimized process corresponds to the TRIM and EXTEND processes in AutoCAD Web & Mobile.
Sebastian
Message 8 of 17
steven-g
Aahhhh, yes indeed apparently this is one of the new updated features, looks like you no longer need to select objects to trim too first, and your squiggly line is a fence rather than window by default. When you start the trim command if at the first prompt you just type the letter 'o' for 'mOde' then you can select 'standard' which is the old behaviour 'quick' is the new updated feature. But I like the fact that it now doesn't need you to preselect objects to trim too it automatically starts trimming objects to the next closest object it detects.
Message 9 of 17
pendean
Community Legend
Community Legend
This screenshot method works best, tied to your printscreen button, grab the freeware version https://www.gadwin.com/download/index.htm#PrintScreen
Message 10 of 17
enz123
I hate the way the quick (Trim / Extend) feature works but it's easy to turn off.
The issue I have is using complicated surveys & site layouts with literally thousands of lines & you want to extend a line accross it all??? Really sucks.
To change from quick mode.
1. select Trim or Extend.
2. from the commandline select 'mOde'
3. select 'Standard'
4. to change back, repeat steps 1 &2.
5. then select 'Quick'
Message 11 of 17
pendean
Community Legend
Community Legend
>>>... you want to extend a line accross it all...<<<
Select the line, click on the grip end, and drag in the direction you want not an option?
Message 12 of 17
rwitzkeJQPDM
Community Visitor
Community Visitor
Thanks .... simple solution.
I suppose there may be some merits to the change, but once one becomes accustomed to drafting a certain way, it is annoying to change. Perhaps when I have a few hours spare, I will give quick menu and some of the other new features a chance ..... but for now ....
Message 13 of 17
pendean
Community Legend
Community Legend
Do you just need to look up the new TRIMEXTENDMODE system variable in AutoCAD 2021's HELP to restore old functionality for TRIM and EXTEND?
Message 14 of 17
rwitzkeJQPDM
Community Visitor
Community Visitor
No, simply select either trim or extend, then right click and select Mode and then select Standard to make it work like it did before.
Message 15 of 17
Hi Thank you. Should the veriable name be TRIMMODE?
Message 16 of 17
info
Observer
Observer
Totally agree with you on this one, cant stand the new way of working with the Trim command. Much prefer the old way having used it for over 20 years. Thanks to all that have answered this.
Message 17 of 17
helloU36C9
Community Visitor
Community Visitor
"But I like the fact that it now doesn't need you to preselect objects to trim too it automatically starts trimming objects to the next closest object it detects."
It does that in the 'standard' mode when you hit return twice anyway. So the new 'quick' mode is actually way more clunky for switching between whether you want to select a trim object or just trim at will.
