Transparent solid color hatch to pdf with lines
Check through the Forum without any clearly solution, try to do color diagram with color hatch in CAD, failed to print hi-solution PDF thru all AutoCAD internal PDF drivers by showing clearly stripes in large area of transparent color hatch. Seems a tremedous technical BUG for Autodesk CAD comparing with ArchiCAD here in Europe.Or am I wrong?
h_s_walker
See my answer in the thread below
http://forums.autodesk.com/t5/autocad-lt-general-discussion/problem-pdf-print-generates-strange-line...
Howard Walker
Left Handed and Proud
Instead of solid hatch use a 2-colour gradient hatch
john.vellek
Hi @Anonymous,
I am not seeing this in AutoCADLT  2017.
I created my hatch using solid and three different transparencies. I then used the AutoCAD PDF (High Quality Print) driver with the settings below.
And, here is the result I have.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Hi John,
Hatching a square won't show the problem. The horizontal streaks appear when hatching an area with multiple vertices because they originate from them, so the more vertices in say the polyline being hatched the more streaks appear. They're easiest to see when zooming in the PDF.
Josh
john.vellek
Hi @Anonymous,
Yes, you are correct that extra vertices can cause this issue. Your solution is also a good one. I changed my solid to a gradient using two colors (the same one in this instance) and it plots fine.
Thanks for your contribution!
John Vellek
pdonald001
This was such a simple solution to a problem that's been bugging us here for a while now.  Thanks!
