Transparency not plotting
chad.aden
Message 1 of 8
chad.aden
I foolishly upgraded to macOS Sierra before being completely done with a project. When trying to plot some floor plans to PDF the transparency hatch no longer appears, it did just fine before the OS upgrade. The plot transparency button wasn't checked so I did that but still not working. That layer isn't turned off to print either. Upgraded to LT 2016 and still same issue. Anyone else have ideas? I tried all three values of PlotTransparencyOverride.
https://imgur.com/gallery/MSKLz
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
LT2016 for MAC has a bunch of updates you need to install, if you've not done that yet.
Message 3 of 8
chad.aden
Working on that now. *Fingers crossed
Message 4 of 8
chad.aden
Installed all three updates with no luck. I did find if I changed all hatches to solids instead of 2 color gradient they appear in the plot pdf. However now they have lines visible. Is there an easy way to remove these?
Message 5 of 8
pendean
Community Legend
Community Legend
Are you using a AutoCAD/LT for MAC? those lines show up from the driver used to create the PDF and/or the PDF viewer being used. In modern AutoCAD/LT for Windows (the forum you are posting in) they're almost all gone now.
Message 6 of 8
Emmsleys
Following up on your thread, please post back with any updates or any additional questions you may have.
Thanks.
Sarah Emmsley
Technical Support Specialist
Message 7 of 8
Emmsleys
Circling back on this thread, if you have a moment to share what work around helped or what resolved your issue that would be great.
Thanks.
Sarah Emmsley
Message 8 of 8
chad.aden
This should have been posted in the Mac forum. The recent update for Mac has fixed this problem. Thanks for everyone's attention.
