Tool Palettes
Tool Palettes
mhotwani
340 Vistas
3 Respuestas
Mensaje 1 de 4
Tool Palettes
mhotwani
I have yellow thunderstorm like symbol. Unable to drag and drop blocks on to drawing.
Need assistance please
0 Me gusta
341 Vistas
3 Respuestas
Respuestas (3)
Mensaje 2 de 4
pendean
Community Legend
Community Legend
The icon simply means those are DYNAMIC BLOCKS, nothing more.
Do you perhaps need to turn on/thaw all of the layers in your file to see them when you slide them into your drawing?
Mensaje 3 de 4
mhotwani
Thanks for info, It partially worked with few, but others not able to drag and drop. I am going to keep experimenting but its a pain!.
I have also brought and re-attached the path within file location in options. But nothing, it only has happened when Auto Cad updated from 2020 to 2021.
Thanks for help.
0 Me gusta
Mensaje 4 de 4
cadffm
That has nothing to do with the thunderstorm like symbol,
and if I am right, you git a message from Acad if you try to insert the block, or not?
Try to insert one of the issue-blocks,
press [F2] and share the last lines with us.
>>" but others not able to drag and drop. "
Is there not a strange cursor symbol? And  no message from Acad[F2]?
Please try to CLICK instead of drag&drop. Same problem?
>>"I have also brought and re-attached the path within file location in options. "
Thjat has n othing to do with the insert-tool of your toolpalette,
RIGHT-click on the tool, properties, check out the path and blockname there!
>>"But nothing, it only has happened when Auto Cad updated from 2020 to 2021."
If the block is present in the location (blockname, filename, filepath) it should work.
Sebastian
0 Me gusta
