The ribbon is empty
The ribbon is empty
meirbitXEY88
The ribbon is empty
meirbitXEY88
I have autocad LT 2016,
I closed the Ribbon few days ago and when I open it again it was empty.
How can I restore the Ribbon?
Thanks in advanced
Meir
Emmsleys
Hello @meirbitXEY88,
Welcome to the Autodesk Community!
When you right click in any blank space on the ribbon do you see the options > Show Tabs > Show panels ?
Try selecting the tabs and or panels you want to see.
Or as a test
Reset settings to defaults  ( Save a copy of your settings as needed)
Let us know if that helps.
Please select Accept as Solution if my post or any other post in this thread resolves your issue, or reply with additional information if the problem persists.
Sarah Emmsley
Technical Support Specialist
Emmsleys
Did any of the posts in the thread help with you issue?
Please post back in the thread if you are still having an issue with AutoCAD I'll be happy to help.
Thank you for your time.
Sarah Emmsley
Emmsleys
@meirbitXEY88
You can also read over this article for additional information about the Ribbon.
Sarah Emmsley
