Text in a circle
Text in a circle
JamesPowell7164
Message 1 of 15
Text in a circle
JamesPowell7164
The company that I work for is allied to the building trade and we produce detail that are annotated with a detail number, a drawing number reference and these are usually contained within a circle.
Does any one know of a way of putting text inside a circle? or do I have to draw a circle and then add text to it?
Accepted solutions (3)
Replies (14)
Message 2 of 15
h_s_walker
Find the sample drawings which are shipped with AutoCAD. You should be able to find a block in one of them which suits your needs
Howard Walker
Left Handed and Proud
Message 3 of 15
Here are my detail callouts that I use.  I made it like I wanted, then made a wblock out of it.  I draw a leader without a hook and insert the block at the endpoint of the leader.  The one that ends in L is for inserting on the left of the leader and R for the right side.  Drag the blocks into your palette and then right click Properties and in the command string line put this macro:  ^C^C_INSERT Udetr _endpoint.  There is probably a better method, but this has worked for me.
Hope this helps.
Lowell McCormick
Message 4 of 15
pendean
Community Legend
Community Legend
In addition to other tips... MLEADER command comes with predefined CIRCLES with Numbers and more: explore.
Message 5 of 15
JamesPowell7164
Gentlemen
Thank you to all three of you for your help.
I know that some of the questions can seem inane but you start off and use the commands once and then once it is set up you forget about them.
Again many thanks to all 3 of you!!!!!!!
Message 6 of 15
Emmsleys
Feel free to select any and or all post's that helped resolve your problem by clicking on the Accept as Solution.
If you still need additional support post back any other questions. Smiley Happy
Thanks.
Sarah Emmsley
Technical Support Specialist
Message 7 of 15
Emma
Nothing really to do with this post but every time that Kudos is awarded to a contributor it shows as 2. Just an observation - is there a glitch with the sight?
Message 8 of 15
h_s_walker
No it's not a glitch.
Expert Elites and above get 2 kudos for every one.
Everyone else gets one
Howard Walker
Message 9 of 15
Autodesk electoral college?  Smiley Wink
Message 10 of 15
Charles_Shade
Message 11 of 15
Emmsleys
Its the first I heard of it @Anonymous I even shared it with my colleague Jon, I can let my manager know.
Also, thanks for the Friday humor guys @Charles_Shade @h_s_walkerSmiley Very Happy
Have a good weekend everyone!
Sarah Emmsley
Message 12 of 15
Slawomir_
Check TCIRCLE command.
Message 13 of 15
steven-g
@Slawomir_ I hope you realize you are answering in a two year old thread, and also in the LT forum where express tools are not available.
Message 14 of 15
Slawomir_
Yes, I realized that right after posting my two cents...
Message 15 of 15
My approach would be to create a circle/square/hexagon Block with a text Attribute Definition (with Middle-Center alignment in the shape). This way, upon inserting the block, a dialogue would ask for the text tag for each tag shape.
