Stretch doesn't work when I select multiple lines on a large drawing, then scroll in to pick a desired grip. It then doesn't move at all or only moves what's visible. This has only just started to happen.
Hi Brock_Olly, the variable is already on 1, just checked another DWG and its fine on that one.
Maybe theres something wrong with the one i'm working on.
Is it a group object? Kind of hard to figure out what's wrong with so little info.
Blocks/group objects stretch in different ways, if it's a group object you can press ctrl+H to edit the lines individually.
@paul_stevensDRA5E wrote:Maybe theres something wrong with the one i'm working on.
Could be: try fixing it
Thanks all, seems that the drawing was slightly turned in 3D, unfortunately I only have LT so had to get someone else to fix.
