Something has changed in my setting, I assume.
Solved by cdbobo17. Go to Solution.
Solved by pendean. Go to Solution.
the blue line is what I am drawing. Instead of starting at 4' along the line, it jumps across the drawing, sometime not as far, never along the line.
I tried f3, no change. I dont know what q2 is..
This all started today.
Hi @ cdbobo17,
Sorry to hear that you are having an issue like this. I also tried running the same workflow in AutoCAD LT 2016,2017 and I wasn't able to recreate the issue.
Is this happening with all files or only a specific few?
Can you post a drawing file in the thread?
Excuse me, you replied "I figured it out." but you didn't give us the answer. I'm using AutoCAD LT 2019 and I can't figure out where the offset starting point has gone.
Example: I draw a horizontal line 4' long. Then I hover over the endpoint and want to draw a vertical line 1' from the end. I used to be able to move to the right just a little and put in 1' or whatever the measurement is and the vertical line would start at that point.
How do you do this in AutoCAD LT 2019?
Thanks for your help.
