Message 1 of 9
I am trying to use the spline command in AutoCAD LT 2020 with end tangencies and the resultant spline is not what I expect.
Using an isosceles triangle as a basic starting shape, the resultant spline is not symmetrical. Sometimes, the curve goes well outside of the three control points. How do I get it to work like it does/did in previous versions?
In the attached pdf, I expect the shape on the right. However, the result is the shape on the left.
I have used several versions of AutoCAD LT over almost 20 years and I can not get this command to work like it has in the past.
What setting needs to be changed?
