Software crashes
Software crashes
Software crashes
I can open the file .dwg but as soon as I want draw something or do something I receive the following message:
AUTOCAD LT cannot continue. You can attempt to save changes into the following file up to the start of the last command: C:\Users\folde.....\file.dwg
After your changes you can open or recover the file. Should Autocad LT try to save your changes?
Either if I press yes or no the software crashes
jayhar
Open new file command RECOVERALL select cad file
or
upload your cad file
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists, Please give me a bit more detail on this issue so we can continue to work towards getting this solved. ?
Thanks You
Jayhar.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
pendean
Community Legend
Community Legend
How to fix a file (there is no one magic method you have to try most of them) https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
jayhar
Error: "AutoCAD cannot continue. You can attempt to save changes into the following file up to the start of the last command"
http://help.autodesk.com/view/ACDLT/2016/ENU/?caas=caas%2Fsfdcarticles%2Fsfdcarticles%2FError-AutoCA...
