Sheet List Tables
Sheet List Tables
Message 1 of 18
Sheet List Tables
Am trying to customize a sheet list table for our company standards.
is there a way to get rid of the "header" row by default? I tried to modify>delete - but the delete button is greyed out.
Also, how do i set the width ofthe columns? currently, my columns default to 2 lines.
Replies (17)
Message 2 of 18
john.vellek
Hi gforsburg,
I usually try to build my Table Style before I create my sheet list. You can create a new Table Style by using the tablestyle command. To minimize the header row I remove the borders, set text and margins to 0. When I insert my table I unlock the Header cells and delete the text. (I know...not exactly what you are looking for but the best I came up with so far.)
As far as cell width you should be able to just grab the grips and drag where you want the edges to be.
I am going to keep looking for a better way to do it and will update my post.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 3 of 18
john.vellek
Good morning gforsburg,
I am checking back to see if my post helped you with your problem. Please add a post with your results so other Forum users can benefit.
John Vellek
Message 4 of 18
Crazy question - how do you "unlock" the sheet style table?
Message 5 of 18
john.vellek
Hi @Anonymous,
Can you give me a better idea of what you are trying to do? Perhaps a sample sheet set and/or drawing attached to a post?
John Vellek
Message 6 of 18
pendean
Community Legend
Community Legend
In order to do what please?
Message 7 of 18
Trying to add a row.  Table says its locked and I don't know how to unlock it.
Message 8 of 18
john.vellek
Hi @Anonymous
You can add rows to your Sheet List. Select the top left corner of the table (it will highlight the whole table).
Rt-click and go down to Rows and then Insert Above or Below.
I am including a Screencast to illustrate this for you.
John Vellek
Message 9 of 18
I see.
I figured out how to unlock the table by clicking the "Cell Locking" Button in the toolbar above.
Insert Row is still not available.
Any ideas?
Message 10 of 18
john.vellek
Hi @Anonymous,
Can you share the file or a file with the sheet list in it on a Post?  That will help me to provide a solution quicker.
You can email the file to me also (for privacy) at [email protected]
John Vellek
Message 11 of 18
Sure!
Message 12 of 18
john.vellek
Hi @Anonymous,
Here you go. I did the steps and recorded them in another Screencast for you.
One way I have avoided doing this in the past is to create one extra drawing in my set. In that file I create a layout for each additional sheet name I want in my list. I then add those layouts to my sheetset so I can manage the sheet list easier.
John Vellek
Message 13 of 18
Very helpful - but im unable to click the top left cell of my table the way you can.  I click the table, then click the top left cell and nothing happens. i click it again like you do and ACAD Command line tells me to specify opposite corner.
Message 14 of 18
john.vellek
Hi @Anonymous,
Very strange. It appears in your attached image that you have selected it.
What happens if you select the table and clear any overrides?
What specific version of AutoCAD LT are you using?
I see that there are proxy objects in the file. If you ExportToAutocAD does the resulting file show the same behavior?
Can you zoom in to the top left corner and prepare a Screencast for me?
John Vellek
Message 15 of 18
Hi John,
I'm having a similar, yet slightly different issue with the Sheet List Table feature.
I've created a Sheet List Table. I noticed it wasn't updating when I changed the name of a sheet. So I deleted the Table by simply erasing it. Unfortunately, now I can't insert a Sheet List Table again at all.
Is there a way to purge whatever past instance of the Sheet List Table may be nested so that I can try it again from scratch?
The only band-aid solution I've found so far, is to go to a different file to create a Sheet List Table, and then copy/paste it back over in my Cover Sheet layout. (but that creates an unlinked table)
Hope you can help, and thanks!
Message 16 of 18
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I'm sorry that you are having this problem with the sheet list. Is it possible to ZIP up the set of drawings and let me take a look?
If your data needs to be private or confidential, please email it directly to me at [email protected] and please include a link to this thread in your email.
John Vellek
Message 17 of 18
Sending over now, thank you John!
Message 18 of 18
john.vellek
Hi @Anonymous,
We worked on this issue offline for a bit.  It appears that the sheet that contained the sheet list had some sort of corruption.  I created a new drawing, imported the layout from the original file using DesignCenter.  I then added the sheet into the sheetlist, removed the original one and now the Sheet List drops right in as it should.
John Vellek
