Setting up shortcut/hotkey/override to drawing commands
So I was a AutoCAD 2004 wiz...
But have been out of the business for 3 years.
But now I have just obtained AutoCAD 2012 LT and I'm looking to configure all my hotkeys/shortcuts/overrides.etc
I do not seem to be able to set any shortcuts for drawing commands...?
I do not want to edit the Alias to change the alias but I want a literal shortcut....
Previously, I could just hit CTRL+D on my AutoCAD 2004 and it would immediately prompt for the circle center point (was shortcut for Circle, Center, Rad).
I don't want to change the Alias to "D" which will require me to hit "D" then "Enter" to start the command... I want to set the direct shortcut.
However the CUI will not let me assign shortcut keys to drawing commands...
I type CUI, then select "Keyboard shortcuts" then I locate the circle command and... there is no option to change the access key like the tutorials show.
(NOTE: I can change the key on other functions like copy/paste but not the useful things I want...)
Can you please help me setup my hotkeys/shortcuts for DRAWING COMMANDS ?
