I noticed when using the blue or green selection box, it would not select anything that was not on my screen. I changed the "SELECTIONOFFSCREEN" from 0 to 1 which fixed the issue, however the blue selection box acts like the green selection box. The blue will select anything inside of it whether a polyline is fully in the box or only partly. The partly elements obviously should not be selected when using the blue option.
i did figure out a solution and it was to set the SELECTIONOFFSCREEN from 1 to 0 then back again to 1. Everything works fine after that. I know it is a small issue however it is very annoying when you are working on several drawings.
I am using Autocad 2025 LT.
