AutoCAD LT Forum
Scaling image that horizontal and vertical scales
4 REPLIES 4
1303 Views, 4 Replies
Using AutoCAD LT 16.
Converting an elevation view from PDF to DWG. It has a horizontal scale (1" = 120') and a vertical scale (1" = 12').
Is there a way to scale this elevation view so that I have the correct horizontal distances and vertical elevations?
Thanks!
4 REPLIES 4
hwalker
Put it in your drawing twice have one of the objects 10x smaller or greater than the other.
Howard Walker
Left Handed and Proud
steven-g
Make the PDF into a block, you can then scale the X and Y axis independently in the toolpalette, but as a note, once scaled some objects cannot be exploded.
Emmsleys
Try bringing it in as a PDF and then adjusting the X and Y as @ steven-g suggested.
Are you only using AutoCAD LT? Are you using other Autodesk product's too?
Sarah Emmsley
Technical Support Specialist
Emmsleys
in reply to: Emmsleys
Following up on your thread, were you able to find a solution or a workaround? Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
Sarah Emmsley
”Boost
