Save Down a 2018 AutoCAD File
Could someone with AutoCAD 2018 please save this file down for me to a 2016 file?  I do not have the capability to save it down since I do not have AutoCAD 2018.
Thank you!
cadffm
Install autodesk DWG Trueview, DWG Convert is part of.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/simplecontent/content/using-autode...
Sebastian
john.vellek
Hi @Anonymous,
As @cadffm indicated in his post, this type of conversion can be done quite easily even if  you don't have the current version of AutoCAD.  You can also elect to download a Trial version of current product to perform such a task.
I found that this drawing had MEP objects that did not want to save backward (not backward compatible) so from AutoCAD MEP I ran a AECtoACAD.
The resulting file still indicates that there are MEP, Civil 3D, and Architectrectural Desktop objects but the file does open OK in 2016.
John Vellek
