Had this problem in the past but solution not working this time. I'm trying to put text at a 45 degree angle. The entire text will move but remains horizontal. Desperate for help.
Solved by paullimapa. Go to Solution.
@mbetGEGZX I did notice ROTATE command everywhere does something different in this file too.
Did you mean to do this?
Two Things: 1. How does one get into the TextStyle dialogue box? (Yep, I'm that bad)
2. Changing the Match Orientation did the trick
THANK YOU!
Use the STYLE command
You are welcome…cheers!!!
