Rotated text tag in block not visible in viewport
I have a user-defined annotatifve block which is a rectangle with a text object (tag) inside of it. I initially did this with a custom leaderless multileader using the ACAD supplied slot block. After several hours now of fiddling about trying to make it work, I've gone so far as to reset ACAD to default settings because I didn't like using the ribbon before but could not find some of the block commands any other way. It's a very long story and I'm very frustrated. I apologize in advance.
Anyway, originally, when I was using my multileader-less tag to number rooms in model space I knew to set the anno scale to 3/32" which is what one of the two viewports will need to be scaled too. I also knew to add 1/4" scale to the tag becauwse I am going to need to scale another viewport to 1/4" In modelspace I inserted my tag, was prompted to input my tag number and then I hit OK and voila there it is on the page.
When I view the layout in paper space at 3/32" it looks exactly as it should. When I open a new viewport and scale it to 1/4" all is still well.
However, I need to rotate the 1/4" scale viewport 90 degrees at which point the slot frame remains and the text disappears.
PLEASE save me from more tutorials going no where!
Thanks a bunch in advance!
Tim
