Overnight my right click customisation menu appears to have stopped working, it allows me to click the box and when I select repeat last command and enter then apply the tick next to right click customisation then disappears. This problem has happened on both my PC and home and are obviously separate from one another.
I've tried PICKFIRST and SHORTCUTMENU and neither have worked.
Any help would be very much appreciated!
Gareth
Solved by GBayliss. Go to Solution.
Thanks for the reply, rather embarrassingly I think I've found the solution.
It appears that its the actual right button of my mouse, as its not registering with my I'm assuming its not active within CAD. I'm currently working on home over a VPN to my PC in the office which would possibly explain why it wasn't working there either.
Seems to be working OK at the moment with a new mouse plugged in.
