Make a polyline (rectangle) that is 32 1/4 by 75 1/4 and radius all corners with a 4" radius.
Now, highlight the line and check properties and what does it read?
Maybe I'm doing something wrong or not adding correctly but it doesn't match.
TIA
DJ
Solved by KateMorricalTowne. Go to Solution.
Solved by nestly2. Go to Solution.
Rounding errors got you. The perimeter of your quarter arc isn't 6-5/16 (6.3125), it's 6.28318. Multiply the difference (0.02932) by 4 and you've got your 1/8" (0.11728) discrepancy.
