Remember folder location and preferences for publish
Message 1 of 23
Is it possible to set publish to automatically find the local directory of the drawing? Setting the default location to a specific directory doesn't work for my use case as I'm creating drawings in multiple locations and always want to locate the pdf in the same folder.
Replies (22)
Message 21 of 23
johnCT6CC
Community Visitor
Community Visitor
The plotter path overrides the path found in the options. Both the Options Plot Path and whatever path is set in the plot dialogue options yes should go to a dummy folder then after one plot, delete the folder and the system will reset.
Message 22 of 23
manuremanager1
OMG it worked!  It is going to the last folder I published to.  🤓
Message 23 of 23
sneenanKFX38
I found a lisp that does this. Hope it makes things easier for ya!
(defun c:PPATH ()
   (command "PlotToFilePath" (getvar "DWGPREFIX"))
   (princ "\nPlot path now matches Drawing path.")
   (princ)
 https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/how-to-make-autoca...
