Hi all,
I'm creating dynamic blocks (in this case different valves within one visibility parameter)
They are all set at a rotation angle of '0'
For example in a drawing, the valves are generally set at '0' but there are instances where the angle changes to '90'
As I've been modifying/troubleshooting the valve block to get it working 100%, when I go to define the block in the drawing it sets all the valves all to '0'
Is there a way to stop the parameters from changing all back to '0' angle and just update the block only?
