I have tried all recommendations in this forum and still recieve the error message. Why hasn't Autodesk come up with a fix?
Sorry, forgot to mention the important bits....
Running Windows 7 64-Bit. Package is AutoCad Lt 2013.
The error always appears when previewing and sending to print.
Oassionally, it appears during normal use if I have been using the package a while.
In my experience, fatal errors are usually caused by file corruption, most often when the drawing contains some objects or xrefs created by another cad program. What usually helps me:
- recover
- WBLOCK
- saveas DXF
I have the same issue with my AutoCAD LT program. It can't be because of file corruption as the program does not crash on the other computers in the office when working on the same files I do. Any other suggestions?
What exact process or command in AutoCAD triggers the failure?
it's not one particular process. some I've noticed are:
-I close a file by clicking on the "x" on the file tab rather than selecting it first.
-while saving
-enterring an x-ref file by right clicking then selecting "open x-ref" rather than opening the file via the menu
Can you invoke the crash at will all the time by doing the same thing? no. sometimes the above mentioned don't trigger a crash.
If this is a random crash there is no cure, no fix for "random" anything really. There must be something different that can be fixed on my program/computer or else this would happen to the others in the office.
What is your LT version? 2015 Windows version? 8.1 running on a 6 GB RAM Is LT fully updated and patched? Don't know. how would I know if this is the case?
There appears to be numerous issues with this error which some are yet to find an answer/fix to. The error affects my office PC but not my home PC. They are of identical setup but office PC has more work related software installed. What exactly does fatal error: Unhandled e0434f4dh Exception at 7c812afbh mean? If it is a memeory address why does it effect others at that same location. I have renamed files, run Ccleaner, re-installed software, removed and re-installed Microsoft updates like.NET Framework but still have the same problem. The issue effects me when previewing prior to printing or printing after previewing. If the error is Windows related then why does it not appear in the Event Viewer logs?
Help and a fix would be much appreciated as AutoCad is proving to be an expensive unusable package....
I am runing Window 7 Professional, 8GB RAM, 64-Bit Operating System & ,my AutoCad 2013 Lt package is up to date.
