Likely the next twelve releases of AutoCAD corrected the OP's issue and there was no need to come back to it.
Or the OP found a solution outside of the Forum and choose not to share.
We could see if D-i-c-k Tracey is available to take up the case and find the reasons there of.
Thanks for joining in and welcome to the LT Forum!
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
I just discovered the same problem. The issue is the scale. Make it smaller and it will work! Knew it had to be simple!
