I can only get quick dimension to work in model space. Is it only intended for model space or am I missing something?
thanks, texteditor.
Solved by Imui. Go to Solution.
qdim also works in paperspace, but only for geometry drawn in paper space.
so.. you cant measure modelspace objects with qdim from paperspace
"Re: Quick dimension
Options
09-02-2016 01:24 AM in reply to: texteditor
so.. you cant measure modelspace objects with qdim from paperspace"
Do you mean I can't DIMENSION modelspace objects with qdim from paperspace ?
texteditor.
I am well aware of that option I just wanted to Know if I could use quick dimension in paper space.
