Qleader and MultiLeader Match Properties?
CalypsoArt
CalypsoArt
I mostly use QLeader in my drawings. However, I've discovered that a QLeader is not the same as a MultiLeader and the ML options cannot be applied. I don't understand why this is?
Anyway, I'm going to try using MultiLeader. Is there any simple way to Match properties from my QLeader to MultiLeader?
pendean
Community Legend
Community Legend
Old commands like LEADER and QLEADER do not have the featuresets of "newer" MLEADER command. Autodesk never dramatically changes an old command, they either stay the way their are for the most part or they are dropped or are renamed to make them harder to find.
So, if you want MLEADER features you have to use MLEADER command.
HTH
