Puzzling with at script for Autocad
skl2AQW6
Observer Observer
skl2AQW6
Observer
Observer
I want to make a script, which creates a square, where lines are joined, and corner are filled radius 5
And further more a text in the middle of the square
Here is what i got so far
_line 0,0 560,0 560,490 0,490 0,0  - works
_SELECT 280,0 560,245 JOIN  doesnt work
then filled in every corner R5
insert a text in the middle of the square
Couldnt find anything on google, that really helped
pendean
Community Legend
Community Legend
Umm, why not just use RECTANG command to draw your square and use the fillet option within that command to create the rounded fillets https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Au...
Honestly though, it looks like you just need a Dynamic Block with Attribute(s).
steven-g
The same question is also asked here
