Proxy information - Missing application : AeccNetwork100
Message 1 of 13
I got the following error when trying to open an .dwg in AutoCAD LT 2015
The drawing you have opened or referenced contains custom objects created by an unavailable objectARX application. You do not need the original application to display proxy representations of objects that were saved in the drawing. However, many manufacturers, including Autodesk, provide object enablers that also allow you to edit these custom objects
Visit the AutoCAD LT Object Enabler Assistant web page to locate Autodesk object enablers or contact the software publisher about object enablers for other applications.
Missing Application : Aeccnetwork100
Product Desc : AutoCAD Civil 3D
Company: Autodesk,Inc.
WEB Address: www.autodesk.com
Total Number of Proxies: 1
Number of objects (no graphics) : 1
Number of entities with no graphics : 0
Number of entities with bounding box graphics : 0
Number of entities with real graphics metafile: 0
Missing Application : AeccPressurePipes100
Total Number of Proxies: 2
Number of objects (no graphics) : 2
Replies (12)
Message 2 of 13
john.vellek
HI @Anonymous and welcome to the Autodesk Community!
Go Here to download the object enabler.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 3 of 13
I have already downloaded all three Object Enablers and installed them, but I still get this error message
Message 4 of 13
john.vellek
HI Nick - Can you attach the file for me so I can see if I can duplicate the issue?
Please also tell me which files you downloaded. You should only have one object enabler for this error message.
John Vellek
Message 5 of 13
pendean
Community Legend
Community Legend
Ask the file creator to "export to autocad" the file they send you so you can avoid the problem. LT doesn't play nice with C3D: if you need it to be you ought to be using C3D as well.
Message 6 of 13
john.vellek
Hi nick.schlecht,
I am checking to see if you got this Object Enabler issue resolved. Please update your post.
John Vellek
Message 7 of 13
Same problem here in AutoCad2015. shared my file. Need a solution please.
Message 8 of 13
cadffm
Same problem - same answer
Ask Software manufacturer for ObjectEnabler for TCH_KERNEL
Contact is displayed inside the Proxynotice
www.tangent.com.cn => mkt@tangent.com.cn    info@tangent.com.cn
For remove Proxy-Message, Use command: WBLOCK (or EXPORTTOAUTOCAD)
!? Your Layout1 isn't fit to the Modelspace..
Sebastian
Message 9 of 13
Inside Proxy Information pop-up box
Missing Application:  TCH_KERNAL
www.tangent.com_CN
How to solve this?
Message 10 of 13
john.vellek
HI @Anonymous,
Are you seeing this error in all your files or just one? Can you share one with me so I can see what the Proxy Object is and perhaps find an easy way to remove it?
John Vellek
Message 11 of 13
Attached is one of the files
Message 12 of 13
pendean
Community Legend
Community Legend
You have to come to the site to post files.
Message 13 of 13
I used AutoCad2007.
And Problem is solved.
Thanks.
