Hii
i cant get print this drawing & also cant convert into pdf pls give me suggestion
Solved by pendean. Go to Solution.
To add; You can reference this article: To Change a Layer's Plot Style
The list of plot styles changes to those in the selected plot style table.
You can change a layer's plot style only if the drawing uses named plot style tables. If the drawing uses color-dependent plot style tables, change the layer's color to alter the plotted appearance of objects on the layer.
If the article and those steps do not help with your print issue please post back with an update in this thread!
Thank you.
Following up on your thread, were you able to find a solution or a workaround? Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
