Hi.
Is it possible to block this Position parameter in blocks etc? It's a bit of a pain in the ack side when you insert objects, blocks into the dwg and this parameter changes - all text it's thick and blury.... how to lock it in 0.
Regards
Cez
Solved by pendean. Go to Solution.
