Populate Annotation Table With Block Attribute Values
We have blocks with physical attributes like model, weight, width etc. I can't find a method for populating a visible annotation table with these values. I'm not extracting these values outside of AutoCAD LT. I just want the attribute values to appear in an annotation table within the block. Is there a simple way of achieving this without using DATALINK or external spreadsheets?
Any ideas?
pendean
Community Legend
Community Legend
Explore FIELDs in AutoCADLT to populate your table with block attributes data.
steven-g
Can you post a dwg or a more visual description? You want a table inside the same block that contains the attributes? Does it need to be an AutoCAD table or is that just a way to describe the layout of the information, and is it only for use within the actual drawing?
