POLYLINE REVERTING BACK TO A STRAIGHT LINE
excadman1
excadman1
I have curved polylines that all of a sudden in my entire drawing turn into a straight line. When i "regen all" they come back correct. What causes this and how to fix?  Thanks
Accepted solutions (3)
cadffm
all what you can"fix" with Regen/Regenall is to save performance
and this is just for the monitor/display.
The data, osnaps, plot - all works fine.
You can not change it, but there is a setting for "how simple" curves look like while saving performance.
Read more about and what the default value is.
Type in and check the setting in your file:
https://help.autodesk.com/view/ACD/2021/ENU/?guid=GUID-77B1C617-E4BB-4D1E-823A-8E2B055B258E
Sebastian
h_s_walker
At the command line type OPTIONS on the DISPLAY tab changed the ringed numbers in the image below. Make sure they are high numbers, maybe 1000 each or more
Howard Walker
Left Handed and Proud
excadman1
Thank you
