Plotter Calibration changes will not stick
       We bought a new plotter HP Designjet T1600. Plotter works great. We print autocad files to real size.  Since then Plotter Calibration changes will not stick. The plotter has an IP address.
I am trying to save the changes to a temporary PC3 file, but it does not work.
Trying to find a path to save, but can't find one.  All our plots have size problems.
How can I solve this problem?
Is there a technician that we can pay to solve this problem?
Montreal, Canada.
Thanks in advance for your help.
Sacha.
pendean
Community Legend
Community Legend
>>>...I am trying to save the changes to a temporary PC3 file, but it does not work.<<<
>>>...Trying to find a path to save, but can't find one....<<<
Can you elaborate please? It is unclear what you tried, where you tried it, and what the challenge is.
-plot
-then chose my printer
-In printer/Plotter I chose the Properties
-went in User-defined paper sizes (printable Area)
-chose plotter calibration.
-I printed a test, mesured it, and entered the new measurements.
-tried to save it to a temporary PC3 file to apply to this plot only.
--(it says: Autocad LT Error) There was an error saving the file to the path I chose.
-tried to save changes to the following file.
-(it says: Autocad LT Error) Please enter a legal filename.
pendean
Community Legend
Community Legend
This will not work, could be a limitation of your Windows login credentials/rights (aka that location is locked to you from adding content to it):
Is that the same folder as the one that comes up when you type PLOTTERMANAGER command? If not, try there instead. if it is, try a different folder that is part of your LT2017 search paths as defined in OPTIONS command's FILES tab, very top entry.
The problem is the path. I am trying to find how to get the path from my PC to our server. I don't know how to do that, but will tey my best.
Thank you for your help.
