Plot to PDF as images instead of vectors
Hi all,
I'm using AutoCAD LT 2014 and would like to create PDFs that are images (i.e. rasterized) instead of vectors. The reason is to provide protection against the PDFs being converted back to DWGs using software such as Able2Extract.
I read some other posts which mentioned MAPPLOTTRANSPARENCY (this command wasn't recognised by my AutoCAD) and PLOTTRANSPARENCYOVERRIDE (made no difference for me).
My current system is to use 'DWG to PDF.pc3' as the plotter. Then I open this vector PDF in another application (PDF-Viewer) and print that file as an image. This works but creates extra steps that I would like to avoid.
Cheers in advance.
pendean
Community Legend
Community Legend
Your method is the best guarantee for what you want: by the way, you seem to not know that starting with LT2017 you can convert PDFs within the program. No need to buy any third party software, just upgrade.
Cheers Dean. Might be time for an upgrade!
pendean
Community Legend
Community Legend
In case you misunderstood, I meant PDF to DWG conversion is built into LT2017, not pdf-vector to pdf-raster conversion.
Yep, understood
