Message 1 of 16
10:35 AM
I have several drawings (some, but not all) that behave as follows (in LT 2015):
1. Limits correctly set to capture desired plot area.
2. Plot set to plot to Limits.
3. Preview shows either only one corner of desired plot or zero entities that should be within limit-defined area.
When I use the plot to Window option and choose the same area as defined by the limits setting, the drawing plots correctly. And, as mentioned above, some of my drawings behave as expected (i.e. the limits plot correctly).
I tried the DVIEW command per a suggested solution found elsewhere, but the subsequent responses did not match those documented in the suggestion (maybe only for full AutoCAD?).
