AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
AutoCAD LT Forum
Post 1 of 9
Plot styles in STB not available in Layer Mgr
179 Views, 8 Replies
08-09-2014 09:31 AM
I edited Acadlt.stb, adding several plot styles to the default one of Normal.  See attached .jpg.  In the layers manager, the added plot styles are not available to be assigned to layers- only Normal is available- see attached .jpg.  Why is this?
Dan
Post 2 of 9
Re: Plot styles in STB not available in Layer Mgr
08-11-2014 03:04 AM in reply to: DBDoug63
Welcome to the Forums
Have you changed your pagesetup to use that style?
Post 3 of 9
08-11-2014 04:40 AM in reply to: hwalker
Yes I did.
Post 4 of 9
08-11-2014 05:20 AM in reply to: DBDoug63
Your DWG file must be set to STB and not CTB: this is not a system setting but a per-file setting.
Look up CONVERTPSTYLES command in help after you confirm the file setting.
Dean Saadallah
AutoCAD, LT and Architecture User
Blog | Google+ | PINS
Facebook | Twitter | LinkedIn
Post 5 of 9
08-11-2014 05:48 AM in reply to: pendean
The drawing is set up to use .stb named plot style tables.  I started the drawing using the Acadlt Named Plot Styles.dwt.  Pstylemode is set to "0:  Uses named plot style tables in the current drawing".
Post 6 of 9
08-11-2014 06:07 AM in reply to: DBDoug63
Shaer your DWG plus your STB file please for others to review: use ETRANSMIT and create a ZIP file to post.
Dean Saadallah
Post 7 of 9
08-11-2014 07:16 AM in reply to: pendean
AutoCAD LT 2013 for Mac doesn't seem to have Etransmit.  I tried to find the .stb myself, but the path shown under Printer Support File Path / Plot Style Table Search Path doesn't show in Finder.  I tried Search in Finder, looking for acadlt.stb, but it was not found.  I searched for any .stb, and found none.  I hate Macs.
Post 8 of 9
08-11-2014 09:49 AM in reply to: DBDoug63
MAC forum is somewhere else, they may be able to trouble-shoot your issue in more detail. This forum is for Windows based users only.
http://forums.autodesk.com/t5/AutoCAD-for-Mac/ct-p/3011
Dean Saadallah
Post 9 of 9
08-11-2014 10:00 AM in reply to: pendean
Ok, thanks.
Post to the Community
New Post
