I edited Acadlt.stb, adding several plot styles to the default one of Normal. See attached .jpg. In the layers manager, the added plot styles are not available to be assigned to layers- only Normal is available- see attached .jpg. Why is this?
Dan
Welcome to the Forums
Have you changed your pagesetup to use that style?
Howard Walker
The drawing is set up to use .stb named plot style tables. I started the drawing using the Acadlt Named Plot Styles.dwt. Pstylemode is set to "0: Uses named plot style tables in the current drawing".
AutoCAD LT 2013 for Mac doesn't seem to have Etransmit. I tried to find the .stb myself, but the path shown under Printer Support File Path / Plot Style Table Search Path doesn't show in Finder. I tried Search in Finder, looking for acadlt.stb, but it was not found. I searched for any .stb, and found none. I hate Macs.
