Plot style location in 2017 LT
I'm home sick from work but trying to work from home. My firm uses plot styles we have created and I have had copies sent to me but I can't figure out where the file In AutoCAD 2017 LT is to add them to my plot style list. Also using a Windows 10 PC which I'm not used to. Cant anybody help me keep my boss happy?
john.vellek
Hi Indicuss
This is the standard path to the plot styles.
C:\Users\USERNAME\AppData\Roaming\Autodesk\AutoCAD LT 2017\R23\enu\Plotters\Plot Styles. You can open this file location within AutoCAD LT by going to Options>Plot and Publish Tab. Select PlotStyle Table Settings and then Add or Edit Plot Style Tables. You should be able to paste in your work styles in this location.
I hope this helps  - feel better!
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
sthompson1021
I can help with the file location but not the Win10 part. If you click on the A in the upper left corner of the screen, then expand the print and click on Manage Plot Styles it should open the folder where they are stored. You should be able to paste in the .ctb files there.
Thanks for the help and the well wishes.
