PGP or NO PGP
PGP or NO PGP
asmckee
PGP or NO PGP
asmckee
I am an old time acad user and want to incorporate my acad.pgp file into newly installed LT. Does LT use acad.pgp or acadlt.pgp?
paullimapa
LT uses acadlt.pgp
If running LT 2024 and up enter the following at the command line & LT will return the location where acadlt.pgp is stored:
(finfile"acadlt.pgp")
You should be able to open this file with Notepad to edit.
Paul Li
IT Specialist
@The Office
asmckee
Thank you
paullimapa
you are welcome...cheers!!!
Paul Li
IT Specialist
@The Office
h_s_walker
@asmckee you can also open it directly from within AutoCAD. See the image below
Howard Walker
Left Handed and Proud
