PDF created from Autocad LT 2020 Drawing _ Adobe Edit Error
Message 1 of 14
Hi all
Recently updated to AutoCad LT 2020 and since then  when  "outputting" a Layout to PDF  now unable to Edit or digital sign it in Adobe.
Error massage come up in Adobe
" Adobe Acrobat has encountered an unknown error"
Any PDF's generated  from AutoCad LT 2019 were and can still Edit / digitally sign it.
Is there a new  security setting or something that is preventing  using some Adobe Tools.
Already spoke with Adobe and they say it is a AutoCad issue.
thanks Juls
Replies (13)
Message 2 of 14
steven-g
Do you have the latest update 2020.1.2 installed, and if so does that fix your problem, part of that update fixes some issues with printing to PDF.
Message 3 of 14
pendean
Community Legend
Community Legend
Which PDF driver are you using exactly?
Message 4 of 14
Hi Steven
Current version update installed is 2020.1.2
Message 5 of 14
HI
Using Adobe Acrobat Pro DC (Version 19.021.20056)
Message 6 of 14
pendean
Community Legend
Community Legend
It appears from other similar posts that 2020.1.2 and Acrobat Pro do not play well together: use Adobe's PDF driver as an interim solution until Autodesk coughs up another update.
And report the problem to Autodesk here https://www.autodesk.com/company/contact-us/product-feedback
Message 7 of 14
Thank you for that, I reverted back to AutoCAD 2019 and using that for now. not ideal but works for now.
Message 8 of 14
mike53NWH
We are having the same issue in our office too (both AutoCAD and LT.) The current work around we are doing is to make a new PDF in our Adobe Acrobat Pro DC session of the error AutoCAD PDF file. After that our engineers can extract pages and apply digital signatures in the new PDF.  It is time consuming, but it works for us at least.
We also noticed the use of watermarks in Adobe was affected too. Anyone else?
Message 9 of 14
pendean
Community Legend
Community Legend
All are known issues: report the problem to Autodesk here https://www.autodesk.com/company/contact-us/product-feedback
Message 10 of 14
Did submit the feedback  to Autodesk back in March 2019. Still waiting on the Update ("FIX") to come.
Message 11 of 14
correction December 2019
Message 12 of 14
pendean
Community Legend
Community Legend
Once? if only one person does it, and only once, that doesn't exactly catch their attention much.
Keep at it, repeat, until a patch is released.
Note: no one from Autodesk will ever contact you if that was the expectation.
Message 13 of 14
mike53NWH
I did submit even before I posted our work around.
Message 14 of 14
pendean
Community Legend
Community Legend
I did too: you're just going to have to wait for an update, or move on to LT2021 when it comes out this Spring if they fixed it there.
OR
Use a 3rd party PDF driver to create the PDF to edit in Acrobat. Lots of freebies out there.
OR
wait on Adobe to issue an update.
OR
Roll back to LT2019 which as a subscription user you are allowed to do legally.
OR
use a PDF editor not from Adobe (the most painful option).
