In paperspace I have trouble seeing drawing lines and text against the white background that is outside the black drawing plot area. This is especially problematic with the yellow color. I can see everything quite well within the plot area which has the black background. I would like to change the white background to a medium gray that will allow me to see all items outside of the plot area. Can I do this and if so how?
Thank you.
Keith Schnadelbach
Thank you; however I still cannot perform this task. I can change the color of the plot area in paperspace but I cannot change the color of the area outside of the plot area. The plot area (24"x36" in my case) is black. Under OPTIONS - DISPLAY - COLORS, I choose BACKGROUND and I can change the plot area to any color I want; however this does not change the color of the area outside of the plot area. I don't know how to change the color of the area outside of the plot area from the glaring white color to a darker color that will allow me to see work positioned outside of the plot area. Is this something that needs to be set up before I perform the first plot? Is that the issue?
Thank you,
Keith Schnadelbach
This is in LT2008
TOOLS
OPTIONS
DISPLAY TAB
Down the bottom left is a tickbox with "DISPLAY PAPER BACKGROUND"
Make sure that IS NOT ticked
Howard Walker
My mistake, I did not understand your intent.
You can't change it in LT: you can turn it off as noted above, or if you want to fiddle with Windows colors there is a post around here that can walk you through it.
I did not find a Windows choice that affected the background here.
I did manage to turn all my other windows black though...
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Thanks for the information. I am able to turn off "display paper background" and change the background color throughout paperspace and that will work for me. At least I know that what I was originally trying to do can't be done and I can stop wasting my time.
Thanks.
