AutoCAD LT Forum
Paperspace background in Autocad LT 2012
7 REPLIES 7
Message 1 of 8
12858 Views, 7 Replies
In paperspace I have trouble seeing drawing lines and text against the white background that is outside the black drawing plot area.  This is especially problematic with the yellow color.  I can see everything quite well within the plot area which has the black background.  I would like to change the white background to a medium gray that will allow me to see all items outside of the plot area.  Can I do this and if so how?
Thank you.
Keith Schnadelbach
7 REPLIES 7
Message 2 of 8
pendean
OPTIONS command, where it's always been, DISPLAY tab, COLORS button.
Message 3 of 8
in reply to: pendean
Thank you; however I still cannot perform this task.  I can change the color of the plot area in paperspace but I cannot change the color of the area outside of the plot area.  The plot area (24"x36" in my case) is black.  Under OPTIONS - DISPLAY - COLORS,  I choose BACKGROUND and I can change the plot area to any color I want; however this does not change the color of the area outside of the plot area.  I don't know how to change the color of the area outside of the plot area from the glaring white color to a darker color that will allow me to see work positioned outside of the plot area.  Is this something that needs to be set up before I perform the first plot?  Is that the issue?
Thank you,
Keith Schnadelbach
Message 4 of 8
h_s_walker
This is in LT2008
TOOLS
OPTIONS
DISPLAY TAB
Down the bottom left is a tickbox with "DISPLAY PAPER BACKGROUND"
Make sure that IS NOT ticked
Howard Walker
Left Handed and Proud
Message 5 of 8
pendean
My mistake, I did not understand your intent.
You can't change it in LT: you can turn it off as noted above, or if you want to fiddle with Windows colors there is a post around here that can walk you through it.
Message 6 of 8
Charles_Shade
I did not find a Windows choice that affected the background here.
I did manage to turn all my other windows black though...
Message 7 of 8
in reply to: Charles_Shade
Thanks for the information.  I am able to turn off "display paper background" and change the background color throughout paperspace and that will work for me.  At least I know that what I was originally trying to do can't be done and I can stop wasting my time.
Thanks.
Message 8 of 8
go to display tab - layout elements- uncheck display paper background will do
Technology Administrators
