Good day,
Is there any command in autocad LT to execute orbit or 3D orbit? Thanks
Hi @j.lumidao
Have you seen the following AKN's about this:
This is the Inventor forum-- perhaps try the AutoCAD forum?
Sam B
Inventor Professional 2018.1.1
Vault Workgroup 2018.0
Windows 7 Enterprise 64-bit, SP1
oh dang @SBix26 I thought it was Inventor LT (just starting my 2nd cup of coffee now, as its apparently needed)
IN the LT there isn't an option for this @j.lumidao as 3d modeling isn't supported by AutoCAD LT
This might help thought
@j.lumidao you could publish to DWF or DWFX and use orbit in design review which you can download from here
"RO" is the command to rotate the the object around a base point. I attached AutoCAD LT keyboard shortcuts pdf for you.
yes... SHADEMODE > Hidden .. then go to View Tab > Steering Wheels > hold middle button for Pan, then hold Shift Key.... Orbit in LT
