Offset command
Offset command
Offset command
When using the offset command, I want to offset a line 24'-0".  When I type in 24'-0", it then asks me to use a numeric distance??  If I simply type in 24, the line only offsets 2'-0"  What am I doing wrong?  Why is it all in inches?
h_s_walker
Welcome to the Forums
Don't put the " at the end
eg just type 24'-0
Howard Walker
Left Handed and Proud
I tried that. its still telling me that it requires a numeric distance.
h_s_walker
At the command line type UNITS. Change the TYPE from DECIMAL to ARCHITECTURAL.
Now it will work
Howard Walker
This is what's going on my end:  I hit the offset command, the window reads "specify offset distance or" beside that is a little box in blue with the word "through".  I type in 24'-0 then click in the line I want to offset. The window then reads "requires numeric distance, two points, or option keyword. Specify offset distance or" the little blue box with "through" is still there. when I try to offset the line, the line just sticks to the cursor and won't jump to 24'.......... what am I doing wrong?
I'll try that now. hold on....
It worked. Thank you so much!
