object in layout space but not in model space
Message 1 of 18
I have never had this issue before, I have a drawing that someone clearly made in layout space and I'm trying to copy it to model space so I can manipulate it and use it for other prints but can get it to show up. I have tried CHspace and a few other things but still cant get the image to appear in model space. does anyone know how to make this happen? im using AutoCAD LT 17 if that makes a difference in anyway
Replies (17)
Message 2 of 18
Alfred.NESWADBA
...which "other things" have you tried and how did AutoCAD respond in the command-line?
_CHSPACE can only transfer objects to modelspace when the paperspace-objects can be clearly identified with a viewport.
If _CHSPACE does not work and you do have a viewport (only one) behind the paperspace objects then please upload the drawing.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 18
unfortunately I cannot load the print because it is confidential but have tried zoom extents and annoall, copy and paste, checked layers making sure they are all on and a few others I cant remember right now. when doing the Chspace command it says the object is sent to model space and rescaled but then when clicking on model space and zooming out there is nothing there.
Message 4 of 18
TheCADnoob
Have you tried making the geometry a block and then inserting it into model space?
CADnoob
Message 5 of 18
the object still does not appear in model space
Message 6 of 18
Alfred.NESWADBA
Create an object in paperspace that is unique to your drawing, e.g. a circle on layer "JUSTNOW", then run command _CHSPACE and select your other objects as well as this circle.
Now change to modelspace, use command _QSELECT to select that circle on this layer, next run command _ZOOM _OBJECT _P
==> do you see the circle?
If not please press <F2> to get a larger version of your command-line, scroll upwards until you see the CHSPACE command call .. create a screenshot and attach this screenshot with your answer.
- alfred -
Alfred NESWADBA
Message 7 of 18
maratovich
Open Layout, run the command "_exportlayout"
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 8 of 18
my circle shows up so the CHSPACE command is working but my original object still does not appear
Message 9 of 18
sthompson1021
Is this by chance a block that has a annotative scale applied to it. In model space, change ANNOALLVISIBLE to 1 and see if it appears.
Message 10 of 18
TheCADnoob
does NCOPY do anything for it?
CADnoob
Message 11 of 18
Alfred.NESWADBA
Which type of objects are the other 11 selected entities? (annotative block could be a good reason to not show up as @sthompson1021 mentioned)
- alfred -
Alfred NESWADBA
Message 12 of 18
pendean
Community Legend
Community Legend
Message 13 of 18
ara_neresesian
HI
CAN YOU SEND ME THE FILE?
Message 14 of 18
steven-g
When you run the chspace command do the objects actually vanish from paperspace, and are they still visible through the paperspace viewport, that would at least tell us that the command itself is working, if it is then there are a number of options as to why it doesn't show up in modelspace for which I can think of 4 options something to do with Layers, Annotation, Color or Scale/Location
Message 15 of 18
Hi, also have the same problem. object can only be viewed in paperspace but not in model space. please help. Kindly check attachment.
Message 16 of 18
hi, have you solved the problem? I also have the same problem. PLease check attachment. Maybe you can help out.
Message 17 of 18
maratovich
All elements are in Layouts.
No objects Model.
No viewport.
Someone was joking about the drawing.
www.kdmsoft.net
Message 18 of 18
pendean
Community Legend
Community Legend
So... move (or copy) it to anywhere you want like in modelspace: either COPY/PASTE or create a scaled viewport then use CHSPACE command.
Remember to scale it afterwards, assuming you know an actual dimension of an object.
You and the file sender need to talk: its between you two what is wrong with this file.
