hi folks,
i switched to a new workstation with a fresh install of acad lt 2024
howerever i encounter strange behaviour i never encounterd in +10 years autocad. On the previous setup everything behave like it should (displaying lineweights)
with parameter LWDISPLAY (show line widths) enabled
in modelspace and paperspace
version autocad LT : U 63.0.0
units: mm
msltscale = 1, psltscale = 1, ltscale = 1
lines, polylines, circles and arcs are shown correctly when dotted, dashed, center etc linetypes applied
however when i change thickness (e.g. 0.4mm) straight lines do not show. Only the essential points are marked with a kind of dot. Even texts in blocks have this issue.
I made a test set, see attachment.
any thoughts regarding solving this problem ? Perhaps an update i missed ?
Harold
Solved by h_s_walker. Go to Solution.
At the command line type GFXDX12. Change the value to 0. See the link below
How to use a previous DirectX version in AutoCAD Products (autodesk.com)
Howard Walker
thanks Howard, that worked like a charm !
I spend a lot of time searching online but could not find the solution.
Regards Harold
