11:52 AM
I need a macro/script to offset a rectangle (by .0625") twice & then change layer of the 2 new objects & do a little trimming/extending. can this all be done in one macro/script/tool button? (i am trying to create a tool palette button to do all of this) below is an example of what i need the finished product to look like. using autocad 2021top rectangle has desired offset lines
..i am aware the offset command has a layer option...here is what I've come up with so far... [^C^C_chprop;\;ltscale;1;;_LAYER;set;hidden;;Offset;l;current;.0625;\\\\;^C^C_chprop;l;\LA;LTLINES;;Offset;L;S;;;X;\;X;\;^C^C_EX;;\ ] it does most of what i want until it gets to the extend function & it just quits.
