Message 1 of 9
I'm getting really frustrated with this issue, maybe someone can help.
Problem:
I've setup a dimension style that uses Myriad Pro font. When I created, it was working fine, but now when I open the drawing in AutoCAD LT 2022 the text has 'disappeared', with just a little dot showing (see screenshots attached). I cannot figure out what is going on.
Some variables to consider:
- I work from 2 locations: Switch between using AutoCAD LT 2015 .. AND AutoCAD LT 2022, working on the same drawing - ie: So I set my AC LT 2022 to 'save as' an older dwg file by default (Saves as a 2013 dwg).
- I have no issues when working on the drawing in AC 2015 - The dimension style with myriad pro displays fine.
- I 'did' at some stage have this style working on AC LT 2022 too, but now cannot figure out what factor changed that means the Myriad Pro font will no longer display when opening it in AC LT 2022.
- I DO have Myriad Pro installed as a font on my PC (I even tried re-installing a few times to rule this out, but don't think this was ever the real issue). I'm using Windows OS 11.
- There is no warning / error popup to say font is missing when opening the drawing and Myriad Pro IS an available font option to select on the dropdown list.
- If I select the dimensions and change to another dim style with different font, then will display OK.
- The is no SHX Myriad Pro file installed, but from what I read, that should not matter as you just need the TTF font file installed to work.
Much appreciated if anyone knows what the problem is here thanks.
